E350 Timing chain tensioner change
GaryRob
2010 E350 Diesel
Im pretty sure I have the common timing chain rattle on start up. It's very slight and only if left for at least 24 hrs.
Im hoping I can get away with just changing the tensioner. Is it a nightmare job?
E350 2010
I couldnt find anything on youtube
Many thanks for looking
Im pretty sure I have the commong timing chain rattle on start up. It's very slight and only if left for at least 24 hrs.
Don’t quote me , but I didn’t think the 350 V6 diesel has a problem with timing chains ? What mileage do you have
G
GaryRob
2010 E350 Diesel
149,000 miles
star
Reading
Smart + others :)
Chains can wear on that engine, not as common as the 651 tho.
The om642 isn't known for issues with timing chains but can happen.
From a quick scout round the web the tensioner doesn't look easy to change but hopefully an indy can confirm.
That said if the chain is rattling chances are it'll need changing.
G
GaryRob
2010 E350 Diesel
Sure it’s not lifters?
Im not to be honest mate. I changed the oil after a long overdue service and it improved masively. If its just the lifters Im worrying over nothing I suppose.
jaymanek
Nuneaton, UK
www.mercland.com
I'm afraid we do a fair amount of chains on these engines.
Normally we seem to do them on ML's.
the chains are usually quite slack when they are rattling and you won't get away with just tensioner. although it's always worth a go.
Avnt
Mexborough
Mercedes c350 cdi estate amg
I had tentioner done on mine 10k ago. The old one wouldnt hold at all. Its still sat on my back wall as well.
John Laidlaw
Wirral
Land Rover Discovery 4
Where you based? Certainly worth getting one of the Indy’s to have a listen
How much was it just to get the tensioner done buddy ?
Avnt
Mexborough
£240 if i remember
mersum1es
Finland
OM642 chain DO stretch, and very common too. I have linked Finnish thread about issue many times, when tensioner indicates clearly when chain is stretched, pictures of old/new chain etc. Note that oil filler hole is not 'at right place' any more in newer engines.
http://www.mese.fi/forum/viewtopic.php?t=52760
Interesting , I wonder what mileage’s it can become an issue ?
Excessively regular oil changes will result in instant catastrophic failures :p:p:p
Er , no they won’t ! :D I’m actually going to knock out a quick oil change this morning :)
mersum1es
Finland
In that discussion they are saying there is no clear correlation to mileage, anything between 200k to 400k
Avnt
Mexborough
What sort of cost is it to have a chain replaced on the 642 engine?
EXMERCTECH
Sutton,Surrey.
C320 V6 Diesel 2005
is this a strip out job or can it be wind on (Pulled thru attached to the old chain)
