MrGundam
- Feb 15, 2021
- C207 2012 E350Cdi
Hi Everyone,
As the title really. Put everything back together after a week working (and waiting for parts) to replace the leaking oil seals. Went to try and start it to check for leaks etc but it will only crank about 3 cycles and then stops.
Video below shows issue:
Had a check with Xentry and no error codes at all related to this.
Only odd thing I noticed was Xentry showing 2 different voltages. One at the top and one in data readings which is odd. I had the car on charge with a Ctek in AGM mode for the past 5 days so assumed no issues. I checked both batteries (large one in engine bay and small in boot) and both show 12v with multi meter so possibly a glitch?
My only other though was due to very low fuel pressure considering so much of the fuel system was removed for the job, however again no errors so just a wild guess.
It is dark here now so thought I would see if anyone has any suggestions I can try tomorrow. If not I will just go through all the sensors again and checked plugged in.
Any help appreciated.
