E500 W211 Engine start and cut out problems
ama singh
Shropshire
E55 W211, W213 C220 CDi, W211 E500 LPG, W204 250CDi
Help please, would be grateful for any recommendations or advice:
My car starts from cold (at least so far) and never let me down, last week I switched off the engine in traffic and when I went to re-start i noticed that the engine seem to crank over for much longer than usual but it started, then again a few days later I switched it off and tried to re-start it again within 10 mins and whilst it cranked over it refused to start. After several attempts it still did not start so I left it for 1 hour and then tried again, this time it started no problem.
I've had this failure to start now a few times and it happened again to me today at a drive through, this time the engine was running while I was waiting in traffic and then cut out and refused to start (cranking over but not starting).
30 miniutes later I tried to start it and it started no problem, I drove home 3 miles and then it cut out again while I was reversing in to my drive - now it does not start
mattuk
London
c320/2001/3.2 v6
So it fails to start only when engine hot?
When u cranking over does the inside lights,cluister and front lights dim?
A
ama singh
Shropshire
SO afr yes, typically when engine i swarm - i've not experienced it not starting from cold.
Lights are all good and the cranking seems to be fast, when it has failed to start I have cranked it over several times before decideding to leave it and then returning to it after 45-60 mins, then it starts no problem.
mattuk
London
c320/2001/3.2 v6
It sounds like u need new camshaft position sensor. About £60 in eurocarpars.
Someone correct me if i am wrong
A
ama singh
Shropshire
How can I test the one on the car? could you tell me where to find it please?
I was also wondering if it could be the fuel filter, I've had the car for > 8 years and don't recall ever changing it.
Triv
Bristol
A brace of s210 1998 e300 turborustbuckets. Toyota HiLux Surf kzn185 3.0L
Camshaft or crankshaft?
A
ama singh
Shropshire
Gents,
I've got a CPS and fuel filter - just need some guidance please on where they are located are on the car so I can chnage them over and see what happens.
We can but try.....
Crankshaft position sensor is most likely culprit not camshaft.
Crank position sensor is located on the bell housing at the back of the engine.
A
ama singh
Shropshire
Do I get to it from under the car? or can it be accessed from under the bonnet?
Under bonnet is easier
top right if you are standing over the engine
see number 5:
Yes CPS for this fault, I had to lay on the engine in mine to get to it and do most by feel, only the one screw and over the starter motor
A
ama singh
Shropshire
Gents,
Thank you! I will go and change it now and report back results
A
ama singh
Shropshire
Gents,
With the aid of the picture and your notes I was able to quickly change the CPS, thank you!
The one I took out had some oil on it and I could see a few metal debris on the end of the orginal sensor - not sure if the metal debris may have been causing the issue.
Have been for a drive to warm up the engine with a few stop starts of the engine and so far it looks good - will post another update in a weeks time to confirm.
Once again thank you!
If possible I would be grateful for a similar picture to show me the location of the fuel filter on my E500 W211, may as well change this over now that I have a new one at hand.
Mu 3 pin one for my CL was only £23 from MB the Bosch versions are cheapest from Bosch service centers
Gents,
Sorry, nearly missed this, Will have a look
Just realised, the fuel filter is in the pump, in the tank.
If you aren't having problems then I wouldn't change it :)
Sent from my GT-I9505G using Tapatalk 2
www.W140.co.uk&www.r129.co
