E55 ATF how to measure level?
tt643
yorkshire
w210 e55 1999
I have just had my transmission oil changed on my E55,we drained the the oil out of the sump and torque converter, 8 litres came out,filled it with the same amount.Took the car for a long drive and when i came back put the dipstick in whilst the car was in park the oil didnt register on the level it should have been.
Then put the car in nuetral and it registered,are you suppose to measure it in nuetral or park.Iam worried now that there might not enough oil in there.
Thanks in advance.
Thanks in advance.
.......... and the engine was running when you dipped it? On auto boxes I've checked the level on over the years, it hasn't mattered whether in Park or neutral
T
tt643
yorkshire
w210 e55 1999
yes the engine was running , in park it didnt hit the mark but in neutral it was hitting the mark.
whitenemesis
CLS55 AMG '05
According to a well respected Indy you "Dip the sump with the dipstick with the gearbox in "N" or "P".
Is it a genuine MB dipstick?
S.Speed
Lancashire
Older Citroen Now :-(
I have a REAL one I no longer use but I really cant be bothered to post...
If you are ever in Lancashire give me a shout and I shall sell it to you..
Pathfinder
Gourock
80 degree versus 20 degree mark
It's very difficult, almost impossible to actually get the gearbox to reach 80. Maybe that is why there is also a 20 degree mark on the dipstick?
Sure, I think the calculation is taken into account :D You can burn your self on hot transmission fluid, hence the cooler fitted.
Pathfinder
Gourock
I'm convinced that the only way to get mine to 80 degrees would be to use a blow torch on the sump.
I checked this a few times recently and cannot get it to go above 70, even after a hard drive and long tick over.
Steve@Avantgarde
Bristol/Somerset
Then I would say you have a thermostat issue which also needs sorting.
The gearbox should be +80'c and running and in Park to be checked correctly or less than 25'c and running in park. The genuine dipsticks have marks for both temperatures.
spock500
Milton Keynes
300TD, 1998
Be careful of those ebay dipsticks. The one I purchased had a painted end which immediately started to flake when inserted.
I have always found it quite hard to read these auto boxes. Sometimes one side of the dipstick will show one level then on the reverse another? The ATF can also be quite translucent, again, making it difficult to read properly.
After the fluid has been 200k miles its much easier to see on the dip stick;)
Pathfinder
Gourock
No thermostat issue, engine temp is nomal. Dipstick is genuine MB, no problems with oil flow.
V6Matty
Newark, Nottinghamshire
had my ATF done yesterday and checked it after, thought i had to much in as i didn't check while the engine was running :rolleyes: will try later when i finish work and hope its got the right ammount in when cold and will check when i get home after things have got up to temp. Oddly enough i did noticed there is a slight whyne when i lift off throttle (not really noticable under load) comes in at about 1500-1700 rpm when moving. now i did notice it before i had the car serviced but as i knew it could have been 50k miles since the last time the ATF was done i put it down to that. Does anyone have any ideas?
Sorry for the hijack btw (i'm getting good at that at the moment:))
The whine sound like the diff to me, the boxes do not do that
MB diffs are not that good, the whine often never gets any worse. It is the pinion bearing thats lost its loading. I think that you would have to disconnect the prop shaft to test but it does sound so familiar. My SL did it
Pathfinder
Gourock
Change the diff oil. 1.2 litres required ,90 grade. Around £5 a litre from ECP with the discount code.
You will need a bottle with a filler tube though, the last litre I bought from them did not have one, but I always keep one on the shelf.
