I actually collect the car next week (I've just purchased it). I am happy with the deal I got - but I'm concerned that I'm going to have to spend a lot immediately.
Does anyone here know the service schedule for the E55?
There is no service schedule as such. The ASSYST system decides based on a number of factors how often the car needs to be serviced and whether it is a minor 'A' service or a large 'B' service. There are also age related items such as brake fluid which comes up every 2 yrs.
If you have bought from an MB dealer then if it needs servicing withing 3000 miles or 1 month they normally have it serviced. The 55 is a complex car and being an AMG the consumables (Brake pads & discs) cost more than the normal E's.
If you have bought cheaply without it being serviced, then depending upon what it needs £500-£1000 should cover a 'B' service at MB or around half of that at an Independent MB specialist.
You may want to start saving up apart from the braking system, I think you have 2 Cats on that model which may require replacing at some pont if not done already.
Mercedes Enthusiast mag quoted £1500 for the Cats but you will need to verify that for your particular year contact an independent specialist in your area if I recall there should be a thread here for them.
£1,500? Ouch. That would hurt a lot on top of any other servicing needed. I hope they've been replaced previously! I'll have to check the history carefully (it's got a full MBSH).
Are the cats usually replaced sometime around this mileage? (119,000)
Not sure about replacement intervals, I found out about this as I was also looking for one, I have since decided to sit tight and save up for a 911 (993).
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
