e55 W210 hydraulic suspension problem
daniel3v6
Peterlee
Hi All,
First hope you had a good xmas and new year :)
You may (or may not) remember me saying about traction problems with my E55, I thought it might be the tyres. I noticed the other day the passenger rear of the car was alot lower than the other side so think I might have a problem with the suspension.
I have the hydraulic suspension system where you can switch between "sport" and "comfort" but I must admit I have no idea about suspension (especially this type)
I checked the hydraulic resovoir at the front right of the car and the level on the front says its just below minimum BUT theres also a dipstick which says its near max.
I have also had the car to a MB dealer and specialist and they said the fluid is fine.
Anyone any ideas?
thanks
nick-E55
Bedfordshire
hi, Others on here will know far better than i, but it may just be the self-levelling suspension, if your car has it. I know the 02+ models did. Made me think twice when i noticed it on my car! :roll:
I would check it in a car park as road camber can give miss leading test
D
daniel3v6
Peterlee
thanks, sorry should have mentioned that. I was in a car park and I have also checked it on my drive. Its quite a difference too not just a little.
On the passenger rear the top of the tyre is almost level with the arch on the other side theres a good 1.5" I would think.
BlackC55
South coast
C43
There are so many things to check.
Does the rear go up and down when loaded?
Are the springs ok?
D
daniel3v6
Peterlee
good point, sorry for being so vague. ill give that ago.
are they any more tests that could be useful?
D
daniel3v6
Peterlee
D
daniel3v6
Peterlee
Found out what the fault was... the damper had snapped but luckly is being replaced under warranty :)
should be getting the car back today yay!
