Egr valve location clk 220cdi 2006 coupe? I think it needs cleaning
Bazhawkeye
Warwickshire
Clk 220 CDi 2006 2.2 diesel coupe
i recently bought the above car, an automatic, which is pretty good but has a problem between cold starting and reaching operating temperature, when it behaves correctly.
Initially, it had a very bad kick when starting off from eg a roundabout, when it hesitated before changing up to second gear. I had the gearbox fluid changed and new filter which made a vast difference.
However, I have a situation where the engine rises and falls, when not under great power, say when driving at 30 mph or 40 mph etc. The rev counter moves up and down around 1500 to 2000 rpm. Some gear changes are a bit rough. Once the engine is hot, this anomaly ceases and the car drives normally.
I think it may be a clogged egr valve, having read various articles online, but do not know where this is located on the engine or how to clean it. Some articles say they can be cleaned in situ, others remove then and manually remove the soot etc. Can anyone help please? Pictures would also help if possible.
Thanks in advance, Bazza
B
Bazhawkeye
Warwickshire
  • #2
With no help from this forum, I found the egr valve, removed it, cleaned the soot off it and replaced it. Not a bit of difference to the cold engine problems but seems slightly more spritely!
'93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
There were about three EGR removal threads running at the same time as yours. The answer on all of them was don't bother it won't make any difference.
B
Bazhawkeye
Warwickshire
Thanks for that. I did look but could not find anything. Can you assist with my car problem?
Not really. Most of my knowledge is petrol but the sitting revs when cold sound like my V8 as it hunts back and forth between gears when cold on a training throttle. My e class also does it.
Specialist Classic Parts suppliers
SLS Im- & Export Handelsges.mbH, Industriestrasse 2 - 4, D-22885 Barsbuttel (bei Hamburg)
Tel. +49 (0)40 656 939-0, Fax +49 (0)40 656 939-399
Visit our website atwww.sls-hh-shop.deto view our comprehensive catalogue of parts for:
190SL (R121), 230 - 280SL (R113), 280 - 500SL/C (R/C107)
Good English spoken and friendly service to discuss your requirements.
