on a w203, looking from the front its more or less top right hand corner (about 2/3 way up from front), it has a small black rectangular cover (with some writing on it, part# etc). Can be a pain to remove but I understand the black cover will come away to allow for cleaning, a more experienced member will have better detail.
.. but this thread is for an ML. I think I have this same item in my car very close to the thermostat! For some reason, it is not what I expected to see on my car
To check and clean the ERG valve you don't have to remove it from the engine. On each side of the ERG plastic cover there are two clips. Carefully lift these and remove the cover.
The ERG valve should spring closed and be opened by the engine management system. Clean it up, removing all the soot and check that it springs closed. I put a very small amount of grease on the moving parts. When finished, clip the cover back on.
Hope this helps
Tom
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
