HI,
I have a WDB2200632A S280 Yr 2000
The car is over heating, so I had a look at the vehicle and found that the fan, which is belt driven, motor or the top of the fan fixing was running at one speed and never reaches the point where it use to really spin up. If I turn on the Aircon, which is only giving out warm air but the fan cuts in and runs at slow speed, or if the engine gets to 95 degrees the fan cuts in slowly.
I have checked fuses 33 and 48 and they are intact and fine. I have not checked any relays, but then I dont know which ones to check.
My initial thoughts are that it could be a heat sensor or relay of sorts, or it could be the motor?
Can someone advise, many thanks in advance
