electric seats
STEc74
St Helens,Merseyside
My car SL 350 05,sons car CLK320,other cars BMW 318IS ,95, 1964 Chev Corvair Monza restoring.
hi i have just fitted a full black and red interior out of a 2003 clk in my 2005 model clk w209 and since doing so my srs restraint service light comes on also the passenger seat belt alarm does not go off when seatbelt is removed or the seatbelt light and the locking off the seat when pulled forward should appear on dashboard and doesnt although these all work on drivers seat. i also have a problem with the driver side head rest goes up but not dwn , only works sometimes it doesnt even go down wen seat pulled forward, can some onehelp me , i have my old seats to take parts from if needed as they worked fine , thanks gavin
toby1
West Berkshire
I think you need it plugging in on STAR to see what's what - see what the panel think
davidsw
cornwall
Jaguar XKR ,Jaguar S-Type, Porsche Boxster S
Re SRS light I think you will find the w209 passenger seat has a different occupancy sensor pad than the previous model. The old sensor has two wires and the new later one has three .
STEc74
STEc74
Hi following my last post on 4th regarding electric seats,sorry for the delay but work kept me busy for a while i have tried changing componants from seats i took out and fitting to seat i put in but srs still shows on dash,although when driving sometimes the srs will go out,smetimes for seconds and other times for minutes but always comes back on again,may be better trying old seats back in just to see if they work as they did before the swap, davidsw thanks for your reply about wiring to seat sensor will check that at weekend.
Another job i have to do is change the worn self adjusting idler on the front of engine are these easy to change,thanks for any advice,Gavin.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
When changing the seats over did you turn the ignition on with the passenger seat removed/disconnected this would be the reason why you are having SRS warning light issues. I think I would be inclined to remove your original passenger seat occupancy switch from your original seat, and fit it in your new seat.
STEc74
STEc74
I think i mayhave turned on the ignition switch when seat was removed i`m afraid i went about it the wrong way,should have fitted seats first i will try swaping occupancy switch as sugested,thanks for info,
bigasotonuk
Southampton UK
Well if you think you turned the ignition on with the seat disconnected then if the donor seat occupancy sensor is ok then it should just reset but as you seem to be getting other symptoms such as the seat belt alarm/warning then this would seem to point the pad is faulty in your donor seat.
