Electric window problems
Gunn
Hi There,
I'm new to the site, just yesterday bought a 93 C180 Elegance, there is a problem with it however, the drivers side electric window and the passenger side rear windows are not moving at all. There is no noise coming from the doors so don't know what is happening! Any help would be appreciated!
Cheers
Hello and welcome,,we have a good member called dec , he should be online later and will talk you through what to do
Dec
Ireland.
W202
Fuses aren’t the problem because the back windows are on one fuse and the front on another.
Try swapping the door switches over to the opposite side just to if that eliminate a possible fault in a switch however it is unlikely that you have a fault in two switches at the same time.
Its probably failed motors, if you are handy with a spanner you could remove the door card to investigate.
See… http://homepage.eircom.net/~decdec/myweb2/new_page_1.htm
Dec
