Hi, first posting on this excellent site! I have searched existing listings but have not found the same problem as I have!
The drivers side window on my 1992 230TE recently started playing up, when pressing the rocker switch to the down position it would go all the way down and would take ages to get back up (turning ignition on and off with swith in up position), also if you operated the passenger window the drivers one would most likely go down aswell! Although obviously frustrating with a little patience I was prepared to live with this small issue with an otherwise perfect car (190k miles). Now it has given up completely, I have swapped the rocker switch with the passenger side and the problem still exists, so i stripped down door and to cut a long story short ended up reversing polarity of wires to motor to raise the window. It seems to me to be likely to be a sticking relay contact, where is it located? Also after stripping down door on a busy street at 5pm in the dark, and initially removing motor and wedging window up with screwdriver, on reassembly and reversal of the motor the window went up at an angle, this must be due to the white nylon roller about the size of a pound coin that was laying in the bottom of the door, where does this go!!!!
I'm hoping someone can give me some advise as the last thing I need is buy yet another Haynes book of lies and remove the negative connection to the battery every time I change a bulb!
