electric windows
kildair
Hi. The left rear passenger electric window does not work (all others do). Any ides about common faults and how to go about fixing them? Thanks
might help if we knew if it was a car or bus or what :D. what age and model please.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Knowing what model and year of vehicle that you have would help.
Let us know based on the first few letters of the VIN i.e. W210 model (E class 1994 -1999 ish). VIN usually starts WDB210 for saloon and SDB210 for estate, if memory serves me right.
A common cause of rear window failures on W210 and W211 vehicles is caused by the window regulator breaking. It's the mechanical linkages used to lift the window. It is possible to replace these and there is a DIY thread covering it.
If you let us know what the model is then I imagine that Malcolm can post a link to an exploded layout picture. I would imagine that mode MB vehicles use similar mechanisms to actuate the windows, but you'll need to use your judgement on that.
wireman
lancashire
Despite you not telling us what its on and assuming that it is silent when called upon to work I would venture a guess that one of the wires in the flexible duct from the door to the frame is broken.
Remove the door card and try disconnecting the motor wires and powering the motor directly from the battery.
K
kildair
Sorry folks. It is a Treg E240 estate. also apologies for my novice question but how does one remove the plastic ducting?
Cheers
Best to remove the door liner and give the motor a clout to see if the carbon brushes are stuck
Would you like the info to take the door card off
K
kildair
yes please. Any info would be greatly appreciated otherwise I will be staring at the door for a very long time worrying in case I cause more harm than good!
I have sent the details to you via Email,,I had to laugh at your last post :D:D
K
kildair
Thanks. Being in the medical field (with a few notable exceptions!) has worked since Hippo's days...;);)
