Electrical mayhem on 51plate SL500 silver arrow
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Recherry, Sep 2, 2009.
  1. Recherry
    Recherry Guest
    I have an sl500 silver arrow and suddenly things don't work, ir rather they work under certain conditions (sometimes). The mirrors will no longer retract with the button. The doors have started locking as you drive off and the most annoying thing is that the mirror adjustment won't work unless you turn the ignition on and open the drivers door. The memory seats work but only on the same conditions but the memory mirror adjustment just picks a random extreme position and after 5-6 pokes of the button decides on where it thinks they should be. Any ideas anyone?
  2. television
    television Always remembered RIP
    164,074
    289
    Your Mercedes:
    Hello and welcome,, your faults are all one thing,, that is a door controller has failed or got water inside. Pulling the fuse out for 10 mins may enable you to do a re set
  3. Chas
    Chas Senior Member
    729
    Feb 23, 2005
    Scotland
    Your Mercedes:
    S320
    This is an option which can be unselected in the settings menu. Its a good option to have as it stops someone opening your door, throwing you out, and stealing your car at the traffic lights complete with car keys :D
  4. nialler
    nialler Senior Member
    151
    May 29, 2006
    Dublin
    Hi Chas
    Just looking at your S320 upgrades, pretty nice, very interested in the command/mp3 options, can you throw a mail my way and tell me how/where you got the software/hardware for such an upgrade, also the led lighting bits I'd be very interested in.
    Ta in advance
    Nialler
  5. Chas
    Chas Senior Member
    729
    Feb 23, 2005
    Scotland
    Your Mercedes:
    S320
    check my posts here.....
    "Mercedes Benz Radios and Navigation Devices
    The Mercedes Player MP40 is specifically developed for Mercedes Benz Radios and Navigation devices incorporating D2B Network connectivity. The Mercedes Player MP40 connects to the Radio and Navigation device per D2B optical fibre The most common devices are:
    Audio 10 CC, Audio 10 CD, Audio 30 (Tel. Keypad), APS 30, SL, COMAND 2.0, COMAND 2.5, Navigation&Sound (smart)
    Existing CD-changer (D2B) will be substituted with the mp3-playing MERCEDES PLAYER MP40. Existing harness can be reused.
    http://www.mercedes-player.com/epages/61733784.sf/en_CA/?ObjectPath=/Shops/61733784/Products/10040
    http://forums.mercedesclub.org.uk/showpost.php?p=371850&postcount=1
    http://forums.mercedesclub.org.uk/showpost.php?p=377865&postcount=55
  6. OP
    Recherry
    Recherry Guest
    Door controller and fuses
    Hi Malcolm / Television. Thanks for the info
    I understand the door locking but don't understand why it just started all of a sudden.
    Malcolm, which fuse looks after the door controllers. How do I get to the door controllers and are they testable?
    Cheers
    rich
  7. television
    164,074
    289
    Your Mercedes:
    It is normally rain and moisture that starts these thing,like anything electronic things can fail at any time.
    All of you faults show that it is a controller,,with anything digital they can lock up (freeze) and only a power down will clear it,,if it can be cleared in this way.
    You should have a fuse chart in with the tools on the car, if not I can look it up but it does take time to check
    An easy way is to disconnect the battery for 19 mins,,though you will have to re set your windows after that
  8. Alex Crow
    Alex Crow Senior Member
    10,677
    33
    Jul 9, 2009
    Super Suffolk
    Your Mercedes:
    another possibility to add to malcolm's words of wisdom is the wiring harness where the wires go from the body into the door. in this area they are prone to bending stresses, a very common problem on the w215 cars. i have known very similar faults to yours caused by a broken earth cable that only made contact with the door open.
    malcolm, remind me, these doors have the parralelogram hinges yes?
  9. television
    164,074
    289
    Your Mercedes:
    No only standard on these cars,,but what you say can still happen, and a good point
    http://www.detali.ru/cat/oem_mb2.as...GA=722.607&CT=F&cat=44F&SID=82&SGR=375&SGN=18
Share This Page
