Electrical Problem - W202 C Class Mercedes
Graybags
Hi all
After a bit of advice regarding an electrical problem which has developed with my 1998 C250 T estate.
Basically the following electrical systems all failed at the same time.
1. Indicators (hazard warning lights working though???)
2. Side mirror adjusters
3. windscreen wipers front and rear.
4. Horn
5. Windows
6. Heated rear window
I pressume its got sonething to do with a common fuse / relay or earth, but not sure where to start looking, the Haynes manual has limited wiring circuits on and the MB dealer said they do n't publish them (or rather they wo n't publish them.
So has anyone had similar problems or could suggest a solution
BR
Graybags
sixpack
Renfrew Scotland
2012 w212 220
Hi.
Are all these accesories ignition controlled ?. It might be the connector on the back of the ignition switch. This happenned to me on a 202, all it needed was the connector on the ig. switch pushed home. Actually it was probably my own fault it got dislodged in the first place as I was fiddling about under there before it happened !. Peter
