adam@bmspares
New Registration
We are about to drive from Melbourne to Sydney (900km) with a slight trans leak from the rear of our trans on our 98 E240. Its leaking from a cable that exits the trans and heads up towards the shifter mechanism. If I remove the boot from around the cable, the leak turns nasty. My question is can I use cheap standard trans fluid as an emergency solution without damaging the trans?
Regards Adam.
Regards Adam.
