Oldspanners
- Oct 30, 2017
- Location
- Normandy
- C CLASS 2004 C180
I used a flat copper washer from a box I bought a long while ago and shows no sign of leakage after two years. I used the Febi oil because it was available but would have no problem using Fuchs and mixing them.Well and good if I could have got the new seals, but it's no big deal. The pilot bushing is not so expensive anyway. I would be happier to completely drain the box, TC and Rad, for sure. Only doubts I have on that score is that I have never drained an automatic gearbox before...but, lots of help here on the forum on that job, se we will see how it goes.
I even have the part Nr for the washer 007603-010100. Is this washer the compressed type? Or just a plain flat copper washer?Surprisingly, not too many for sale on the internet ( that I could find anyhow) but will get one from the local Mercedes dealership. So you use the Febi-Bilstein oil etc.? or the Fuchs?.
Thanks for your help,
Regards Jim2.
A bit of reflection is good if you're not familiar with things but I found mechanically Mercedes parts are robust and making a repair with the right parts and advice is satisfying and great value when compared with professional prices, even if having to buy the odd special tool.
Speaking of which you will need a dip stick, carefully measure all that comes out and don't overfill and check the level and add a little at a time at the right temperature until at the correct level. It all sounds more daunting than it actually is.
