Dean Fletcher
- Mar 24, 2018
- Location
- Penrith, Cumbria
- Mercedes E400
Very nice buddy , good job . Might be my iPad , but does that brake fluid reservoir look a bit full and quite dark in colour ?View attachment 48541 View attachment 48542
Just thought I'd give the bay a quick once over, not bad with a pack of the wife makeup remover wipes and tub of dirt remover.
There will be a marker level on the side of the reservoir , and new brake fluid is not dark unless it's old . It's normally a change every 2-3 years .Yeah I'd imagine so, my indy replaced a bust brake pipe 2 weeks ago and replaced it. Why is it supposed to be clear and half full?
Good stuff , I'll keep my nose out next timeView attachment 48543 View attachment 48544
Just been had a look. The fluid is clear and it seems it's quite full prob over the max level. I live on a hill that's why it looks higher to the right.
Hahaha thanks for noticing anyhow.Good stuff , I'll keep my nose out next time
I've been watching endless Youtube vids on engine detailing, trying to screw up the courage to spray the APC around and give it a light jet wash.
What is putting me off is that you need to cover any sensitive electrical bits before doing this... and I don't know where they are.
I'm not a mechanical numpty, but I'm really struggling to find what, if anything, I would need to cover up with clingfilm, foil etc.
I think part of the problem is that there's so little access around the engine. Should I remove the engine cover(s) to get better access before cleaning?
Yes , I must admit to have chickened out on this aspect as well. I restrict engine bay cleaning to waterless wax and and a wipe over. You're bound to get better access for cleaning by removing the engine covers though.I've been watching endless Youtube vids on engine detailing, trying to screw up the courage to spray the APC around and give it a light jet wash.
@Wighty where in the engine bay would I find the ECU plug? The stupid car went into limp mode again this morning but soon as I turned it on and off it's been fine all day. I want to check the plug as last time this happened and the same code came up my Indy said my ECU plug was dirty he cleaned it and it been fine for 6 weeks.I have given the engine a light jet wash in the past , spraying from a distance after using APC or degreasant . One point to watch is the oil filler cap , which can collect water in the rubber seal around it .
If I were you first time , why not leave the cover on which will cover most electrics and concentrate the cleaner around the actual engine bay . Fold a microfibre cloth over the oil filler cap , which will stop water pooling there .
There are people who would never jetwash an engine , I do , but from a distance as more of a mist .
Looks decent!A303 Aerospace protectant
