Engine Cleaner
DPP
Hampshire
S Class, 1991, 300se
I have an MOT and can anyone recommend a good engine cleaner to give a good blast to the components, there are a few on the market but most are unsuitable if you have a CAT Conv.
I have a 300 se 1991 which has about 130k on the clock
When doing under the bonnet, I spray selectively,,I cannot see any of the cleaners as being a problem. by just cleaning off a small area I agitate with an old paint brush and rinse off with a kettle, to stop water from going where I do not want it
Dosco
W211
Do you mean an external engine cleaner or an additive to 'clean' the internals of the engine?
I never gave that a thought with my one track mind :( and I could not possibly see why cleaning the engine would damage the CAT
rpe2
Silchester
Take it out for the good ol' Italian Tune Up...'
Silver_Star
^^ What this man says. Take it for a blast at 60/70 and leave it in 3rd/4th gear if a manual or lock it in a lower gear if an auto.
I have always used the forte products and found them to be good.
I would steer clear of engine flush's though as often they can cause more harm then good.
kth286
E320 Coupe 95
make sure plugs are good and correct ones.
and clean air filter.
D
DPP
Hampshire
100% Pass
Gave the car the Italian Tune Up and also added a bit of injector cleaner, it seemed to do the job as it passed 100% without any problems.
No advisories so 12 months of happy motoring. Thanks for the advice.
I say no advisories he did mention a squeak in the front suspension.
craig amg211
cambrdgeshire
03 e55 amg
i would not use a fuel additive with the fuel level low as the measured gases would contain the cleaner/ additive giving a higher reading,an italian tune up will help and testing when hot,i see you have a 1991 car.if i remember correctly cat testing is for cars 1992 onwards
