jon pollard
- Apr 2, 2005
I need to replace the Engine Coolant Temperature sensor on my 2001 W203 C200K. I think I've located the sensor, high up, in the centre, at the front of the engine block just back from the radiator (confirm?). Can anyone tell me if it's just a case of unplugging the wiring connector and unscrewing the old sensor before replacing with the new one? Or is there going to be any coolant leakage? i.e. do I need to drain some coolant first and then top up again later?
Hopefully it's as simple a job as I'm hoping
