joderest
- Apr 16, 2018
- ML270 2003
I thought it was all going too well, ML270 has run for nearly six months without a problem, Then.......
Going home last night, was going round a bend at about 25mph, foot off throttle, and suddenly, no steering, or very heavy, looked down and all lights on dash on, no power steering as engine had stalled. Drifted over to curb, shifted into park, turned key and it started, drove home.
This exactly same thing happened about a year ago. This time i have read and logged the fault codes..
B1704-004
Transponder:error when writing programmable code
B1703-000
The transponder cannot be read
B1858-002
Radio signal:freeze code normal, but variable code not synchronization
P1354-000
The fault code is not found.
All codes were stored and have deleted, a 2nd check confirmed none returned.
Can any one make any sense of this for me?.
Cheers
PS: its a long time since having the scanner connected, so not all may relate to this issue.
B1704-004
B1703-000
B1858-002
P1354-000
Cheers
