Alan J
I wonder if anyone can suggest an answer...? The engine cuts out randomly: this can happen at high cruising speed (in which case it sometimes restarts on its own), at low/idle speed, when trying to restart whilst warm. The effect is just like the ignition being switched off.
It will restart after 3-20 attempts and then behave normally for anything between a few minutes and a few weeks without recurrence. When trying to restart, the engine will start 'normally' and then cut out after a second or so.
After enough tries, instead of cutting out it will give a cough and run happily - until the next time!
Also, when coming to a halt, the engine revs sink almost to stall (about 500) before recovering to 700. Idle wanders between 500 and 750.
I'm tired of being told to wait until what ever it is fails completely! It's often embarrassing and occasionally dangerous and it's taken away my confidence in the car...
Thanks,
Alan J
Thanks,
Alan J
