Engine dies Problem
Greasy Reesy
1999 mercedes slk 230 kompressor
Hi, Guys, I`m new to this I hope somebody can help. I have a 1999 slk 230 compressor with ongoing problems. I have had problems with starting which I have cured however I have now developed a problem with the engine just cutting out on test drive and will not restart until it has completely cooled down.
I have recently changed the K40 relay, fuel pump, fuel filter, and cam position sensor i have just ordered a new MAF unit do you think I am going down the right path???
Thanks in advance Greasy Reesy
No. Have you put it on diags? Guessing gets expensive quickly.
AMGeed
Poole, Dorset
S204 C180K
Sounds like the symptoms of a failing Crank position sensor.
G
Greasy Reesy
No I have an OBD 11 which I cannot get to recognise the vehicle
Yes my thoughts too but reading codes/viewing live data will soon confirm.
G
Greasy Reesy
Hi Guys, Thanks for the response as you suggest LostKiwi I think I will book a diagnostic check. One thing since my last post I checked over my fitting of the new fuel pump and filter which was good. I noticed a split hose on the F1 Carbon filter. Could this be my issue ????
G
Greasy Reesy
By the way I am based in Cardiff South Wales.
There is a very good independent Mercedes specialist not far from you...
It's the guy who posted about the crank position sensor. You couldn't do much better than paying @Steve@Avantgarde a visit.
G
Greasy Reesy
Thanks, I`ve already booked a diagnostic check for Monday I will let you know how it goes.
