Engine idling problem
kanda
I am having this problem lately, while driving all of a sudden when i slow down the idle very rough. Its idles like its going to stall and even i press the accelerator it wont rev up. I got to switch off and restart and all is okay. What could be the problem, has anyone had this problem.. Model W124 - 1989 -230e . Need a solution last it happen it the middle of the highway and its very dangerous.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Had exactly the same problem on my car and only last week cleaned the Throttle control valve with some carb cleaner and an old tooth brush it is now absolutely perfect.
Dont forget the OVP relay item 86-89 in the link below, this can cause a rough idle, as well as the above threads. this is a well known fault,they suffer from dru joints and the fuse blowing.
Malcolm
K
kanda
okay guys i will try out all the suggestions and see if it works out. Thanks friends.
K
kanda
Malcolm
I have changed a new ovp relay lately and this problem comes only when i slow down in a traffic, otherwise the does fine
