engine jerky in summer, ok in winter
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
yup, that's about it, when i'm driving below 70 km/ph in summer (noticed it a month ago or so when temps rose above 15c) the car is jerky (best I can describe it, almost like it wants to cut out but doesnt) in low gears but fine on a motorway crusing at 120km/ph.
however, in the winter I do not have this problem at all, its smooth in low speed and high speed, I've replaced the viscous fan coupling and the temp does rise but not too high so what could be causing this ? the maf ?
mattkh
England
A160 W168 1999 1.6
yup, that's about it, when i'm driving below 70 km/ph in summer (noticed it a month ago or so when temps rose above 15c) the car is jerky (best I can describe it, almost like it wants to cut out but doesnt) in low gears but fine on a motorway crusing at 120km/ph. so what could be causing this ? the maf ?
Do you know which temperature sender is used by the ECU
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
absolutely no idea, how can I find out and where would it be located ? its a merc c220/1995
cheers
anyweb
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
If you wait a week, Malcolm may be able to help !:mad:
lol
Adam
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
As your problem seems to be caused by the change in ambient temperature I would think the intake air temperature sensor is the most likely culprit. It is located in the air intake trunking just before the throttle/idle control valve and is just clipped in place , check it has not become contaminated by oil or the element has not broken, be careful it is fragile .
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
got a photo of this location C220GJS ?
cheers
anyweb
C220GJS
Shotts, Scotland.
To check the sensor ,remove it and check the resistance using a meter.
Resistance at 10c ambient 9186-10153 ohm.
" " 20c " 5757-6363 ohm.
" " 30c " 3705-4095 ohm.
Hope this helps ,it seems the likeliest culprit to me.
www.W140.co.uk&www.r129.co
