acecats
My 1997 SLK 230 Kompressor's air con condenser was replaced after being holed by a stone (according to local garage staff). When I picked up the car it started to misfire shortly after driving off. I nursed it back, the engine cutting out a few times, to the mechanic who did not know what the problem was. After some thought it may be that some water from the radiator may have got into the air intake pipe which was also detached in the repair and therefore reached/affected the AMF or even the engine. Does anyone know if this is the likely problem, is it major and what is the solution?
Thanks.
Thanks.
