engine oil addative
mercman111
ledbury
2005 clk 350 petrol
which engine oil addative works for a 2003 clk,thanks in advance
Gazwould
C250 CDI
Just upgrade the manufacturer oil spec to a higher one.
What spec / oil are you currently using ?
ajlsl600
france
Never put addatives In My oil 40+yr if needed prob another issue needs looking at
M
mercman111
ledbury
2005 clk 350 petrol
not sure ive only just bought the car
Gazwould
C250 CDI
Wynn's hydraulic valve lifter treatment ?
M
mercman111
ledbury
2005 clk 350 petrol
not diy,its an old car,not old enough to be worth anything
Conor
London, UK
I agree with this sentiment.. but I'm currently in two minds (hopefully this isn't a pure thread hijack and is somewhat linked to OPs circumstance)..
Anyway, my car is just about to hit 200k and burns a lot of oil and at least the valve stems seals/guide are done for. I am flip flopping between:
1) Bangernomics - No more engine work and just use a heap of additives / thicker oil (10w/xx) to slow the oil burn. Then scrap it once the cats burn out and fail the MOT.
2) Go all in and drop a few grand on engine rework - potentially full block re-work. But then the car is probably good for another 200k miles.
Both of them seem like logical approaches in my opinion. I just don't like the idea of driving something into the ground because of the engine, when the rest of the car is still great.
It's often not a question of how much it's worth but more a question of what it's worth to you.
Cost of replacement is the overiding factor I use on our 210. If cost of replacement is less than cost of repair fix it.
Lifters aren't expensive or difficult to replace on most cars.
For example our M112 a single lifter is £15.
