oigle
- Mar 15, 2005
- Age
- 83
- Location
- Redcliffe, Queensland, Australia
- Website
- members.optusnet.com.au
- 2003 ML270 sold but not forgotten. 2022 Kia EV6 RWD LR
Yes on the jeep the trams is cooled through a traditional exchanger in the bottom of the radiator. I was tempted to just do a bypass loop with the cooler mod, would have been easier, but every listing or detail I read about it called it a cooler so thought I would err on the safe side. I tow in our heat as well so thought that was a better although harder option.
The jeep also has a steering cooler as the coolant fan is hydraulically driven. One of the jeep guys is about to play with a trans cooler. It's a B & M one with fan but he intends to block off the radiator exchanger and I don't agree with that even if the trans one has the fan. It's still only about 300square which I think is still not big enough to work alone fully.
I'm not opposed to the MB fluid for a change at say 5litres x $25 but I have a small trans issue and wanted to flush most of the old stuff out so 15 liters x $25 hurts a bit. I'm having an issue with the trans shutting down and dropping into netural with engine shut down as well. Not often and random. Previous owner ran a specced Penrite oil with no issues and I recently changed to the Nulon but want a true approved MB oil to cross it off as a cause.
I think it is definitely best to incorporate the old heat exchanger in the rad with the extra cooler. Brings oil temp to proper level. Be sure to plumb it with the oil going through the new rad cooler first and then back through the bottom of the rad. That makes the cooler more effective and also makes sure the oil is then brought back to proper temp if it is overcooled by the extra rad in winter.
