msejensen
Registered
Hello, I have some problems with my Mercedes 190 2.0 1988 with Pierburg 2E-E carburator.
1. When I try to accelerate the engine stalls for a few seconds. Then all of sudden it accelerates. The behavior is worse when engine is cold and at low RPMs. When the engine is warm it it doesn't stall, but it will hesitate as I press the accelerator. The behavior is only present under load, doing the same thing with clutch down will not show any problems, it will gladly rev.
2. When driving on the highway at constant speed the engine will gradually lose power over a time of some few seconds. Then all of a sudden it will snap back with full (normal/expected) power. Then after a few seconds it will gradually start to loose power again. It will then go on like this and repeat the cycle.
I suspect the second issue is related to the first, but I have no clue what the problem may be. I would greatly appreciate any help.
Regards
Regards
