Engine warning light goes on and off
rosslyn
I have an 2002 E280, when i floor the car and hit a high speed in a quick time, some times not allways the engine warning light comes, an dthen may go off next time i get in the car. Also since this has started happening the car quite often has slow uptake from a standing start, eg the you put your foot down it moves slowly then kicks in it may, the engin emay even stop all together when stationary in traffic, any one got any ideas please
Cheers
Rosslyn
This should just be the MAF sensor gone down
£57 for the insert that you put into your own plastic tube,£157 from any Bosch outlet, or £250 from MB
R
rosslyn
MAF Sensor
Hi Malcolm
is this easy to for yourself, or can my garage do it, do you think the £57 option will do.
KR
Stuart
For the £57 option you have to remove the MAF (easy to do your self) and unscrew it from the plastic tube, the buy this part from any Bosch service center.
Once I know what the car is I can tell you more
http://www.boschautoparts.co.uk/#
go to the dealer location
R
rosslyn
Hi Malcolm
Its a E280 VIN- Wdb21xxxx2b363201
2002
R
rosslyn
Maf
Thanks for the link is the MAF the whole thing in the diagram or one of the parts.
R
rosslyn
Hi Malcolm i kno which part it is now in diagram, do you know where it is on teh Bosch site, so i know i buythe right thing
The sensor in the tube has a part number on it, it is this one and not the part number on the tube,,
You could just pull the plug out and try the car,,some will run well with it unplugged and some will not
R
rosslyn
Buying the part
Hi Malcolom
I'd rather buy the part and fit it, wher can i ge the £57 part from, cit would great if you could help on this. You are also helping me ouyt on teh parling sensor trhread as well, cheers for that you'er a god send
KR
Stuart
I had to go out and buy some food,,you need to get the part number off the sensor in the tube, then ring the Bosch service centers in the link that I gave you, and ask for that
R
rosslyn
MAF Sensor
Hi Malcolm
I have sourced the MAF unit now. One thing i did not ask is do i need to buy the MAF unit and a new sensor.
In order to get the sensor out it requires a tool i dont have, as it is a funny screw head.
Cheers
Stuart
Hi Malcolm
Cheers
Stuart
Yes the screw is odd,,, any security torx will get them out,,you can replace them with normal screws, dead cheap form Halfords
Do I need to buy the maf unit and a sensor
The MAF is the whole thing in many cases,,but when you buy the sensor only you save £100 for the new plastic tube that it fits in, so when you can just by the sensor part that screws on,do so
www.ckinsurance.co.uk
