Engine warning message
Guohong
2015 C220 diesel
Haven't been driving a lot lately due to lockdown and mostly short distance. A red warning message appears everytime with a battery pattern and says "Stop vehicle, read owners manual". It's been quite a while since this appeared first time, vehicle runs fine. Checked the voltage, 14+V when engine runs, drops to ~12V when stops, so supposedly alternator is good. Any advice please? Thanks a lot.
John Laidlaw
Wirral
Land Rover Discovery 4
A good battery should be 12.6v or more when stopped and at rest for a time- if it's the original battery from 2015 it will be at it's end of life.....
Oh, and welcome to the forums !
G
Guohong
2015 C220 diesel
thank you for the prompt reply. I suspect it's the battery just want some confirmation!
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
12.6v is the ideal voltage of a healthy car battery, around 12.0v is indicating a 50% efficiency level, and as @John Laidlaw said ^ :)
John Laidlaw
Wirral
No problem! Modern cars are quite hard on batteries, they rarely last past 5 years nowadays....
(that comment is sure to trigger off loads of posts saying they've had the same battery for 30 years with no problem, etc etc... :oops: )
G
Guohong
2015 C220 diesel
yes, the start/stop function stopped working quite a while ago (because battery was not full) but it didn't bother me. I wasn't too sure because we haven't been able to run long distance and properly charge the battery for a long time.
malcolm210
Try Tanya online and Varta batteries are OEM, my battery from them arrived next day, give the battery a top up charge before fitting, a battery at just over 12V is almost flat
G
Guohong
2015 C220 diesel
Will do a bit of research of what battery needed. Lukily the current battery starts the engine without any issue so I guess it's not that urgent.
It seems nobody will recommend Halfords? Got a trade card there.
Give MB Grangemouth parts dept a ring , mention the forum for a discount , they deliver for £5 .
G
Guohong
2015 C220 diesel
  • #17
well, it seems they have used batteries?
£46 is really good price, a bit too good... on Tayna it costs £120.
Janchee
Ex W213/2016/220D 190
Yeah, If I were you ... I'd get it replaced as MB start to do funny things with a low voltage! I'd just go genuine from contact details provided above however, Tayna offer 4 year warranty on some batteries? (don't know how good it is though!). BTW were you measuring battery voltage whilst it was still connected to the car?
Also, as @bembo449 said, get a trickle charge on it and see if it comes back to life!
Cheers, Jan
davidsl500
If you haven't been driving much recently as you say you haven't due to lockdown then first of all try charging your battery with a smart charger. My battery goes from 100% ( 2.8V) to 50% (12.0V) if not used for 2 weeks as a guide. No point getting a new one until you have tried that... The better half's Polo which is used for 10 mile round trip shopping was down to 12V and is now back to 12.9V after a good charge. The cold spell wouldn't have helped things either.
malcolm210
^ +1 Charged the battery on my daughters 1 series BMW yesterday the car has been used for about 20 minutes a week for the last 10 months and the battery was <half charged it needed a 7.5hr charge with my MSX 7.0 to get it to full charge. Did the same with my son’s 220d the week before and his battery was in a similar state - looks like being a good year for battery manufacturers doesn’t do batteries much good sitting less than half charged
