umblecumbuz
- Sep 20, 2010
- Location
- Wales and Gozo
- S204 and CLC 204 cdi, MX5, Kia Soul
Has water got into the bores while the injectors were out?
Sounds like the starter is doing its best, but hitting big mechanical resistance.
As Wighty says, you need a long bar to begin turning the engine over on the crank - a short spanner is not good enough.
If it has got rust in the bores, turning over by hand several times might help free it up - especially if you can get a few squirts of oil into the bores as you do it. Of course, removing the injectors will significantly reduce the turning effort needed.
I think we're clutching at straws a bit here. Feel for you.
