GOLDEN MOTOR
- Mar 4, 2007
I Have S400 2001 with twin turbo engine .. the EPC MIL lights up while driving i test it by scanner its show this fualt code P2021 .. I change the (Y74) Pressure control valve but the problem is still ,, then i see if i remove the socket for rail pressure sensore.. the EPC light come in the cluster..
i change the sensor as well .. :sad: :sad: still same problem,, pedal sensor also
i have no problem if the car stop ,, its very smoth at idleing speed even if i increse the rpm up to cut off,, the problem just while driving
then i take it to mercedes dealer thay change the O rings for the rail and reflash the ECU ,, SAME SAME
Anyone have any suggestions on to what the cause and best remedy for this situation
Best Regards
Younis
Best Regards
Younis
