Hoopsville
Registered
- Dec 17, 2021
- E250 blue efficiency 2009 OM651, GL350 bluetec 2013 OM642
Hi All,
I’m getting irregular exhaust gas temperature readings from my EGT sensor upstream from the SCR cat. It jumps from what appears to be the correct value (it varies depending on operating temp) to -0.04 degrees, and back. I thought it was the sender but if I disconnect the sender, the CDU (as it’s supposed to) puts up an estimated value (for me last night is was 5 degrees higher) - however that value also jumps back and forth to -0.04 too!!!
Anyone experienced this?? Any ideas welcome.
I’m using Xentry via pass thru, and on Diagnosis > SCR > Temperatures > Actual Values.
Connection/wiring looks ok. I’ve tried the “teach in” process for the sensor on Xentry too.
Car is ‘13 W166 GL350 Bluetec
Thanks ++.
Hoopsville
Thanks ++.
Hoopsville
