ESP/ABS,SPEEDTRONIC Warnings
SL350BALLY
SL350 (R230)
Hi all, apologises if there is already a thread on this, but does anyone have any knowledge of how to reset/clear the below warnings?
As a bit of background the car was running perfect with no issues, when out of no where whilst driving all electrics cut off, i managed to pull over safely, but i had no electrics and couldnt even open my door, lucky i had the window open whilst driving and was able to use the manual key.
Turns out the battery cable had some how sheared off from the terminal whilst driving, which is crazy and also lucky I wasnt at speed. (not sure how it sheared off as battery was secure)
I now have the battery terminal issue resolved but now have the below warnings, the car seems to be limited to 30mph and doesnt change gear? any one able to shed some light on how this can be resolved, it would be appreciated.
Note : I have tried the full lock turn, and also driven the car for around 4 miles but the warnings persist.
peterws1957
Lancashire
Sounds as though the car has gone into limp mode. Probably the broken battery cable has caused an electrical problem - perhaps a short somewhere or damage to the alternator or its regulator. I doubt that this will be resolved easily without a STAR diagnosis.
ajlsl600
france
Read codes. Note and clear is prob only way, if issue solved lights shud go out.
I use icarsoft v2 and it does that easily unless fault is active/current.
In my view some kind of decent diagnostics is mandatory on modern benz, maybe all.
SL350BALLY
SL350 (R230)
A visit to a specialist with STAR is the plan, hopefully they will be able to do some sort of reset.
SL350BALLY
SL350 (R230)
Yes mate, worrying thing is how it could have sheared off, then again the amount of pot holes around these days, doesnt do the car any favours, but thats another story
Hope you have left enough slack on the cable for engine movement.
ajlsl600
france
Cut batt cable will 4 sure bring on a load of voltage issues. (as in no voltage!) . Icarsoft will be able to delete any historic codes
SL350BALLY
SL350 (R230)
Tried icarsoft, unable to clear these errors
ajlsl600
france
ajlsl600
france
"drive to workshop" particularly useful!!!!
SL350BALLY
SL350 (R230)
OK a bit surprised . Perhaps ur goin to need xentry, tho I don't know why.
Will see if anyone local has that. Read up the car may need sensors resetting etc
ajlsl600
france
How old is car
ajlsl600
france
OK so can't blame makers. Prob someone gave it a wrench in thecpast as it came out of terminal I guess nothing shorted just (as cars. Go) a massive power failure tho consumers prob still powered by aux batt.? I wonder if alt reg screwed in process, but in reality guessing.
Best get it onto something xentry that can better interview the car. Do advise when you get solution
SL350BALLY
SL350 (R230)
Will do for sure
SL350BALLY
SL350 (R230)
Okay had the car plugged into star at a local specialist, no comms at all with the esp! So cannot clear errors, been told will need further investigation to diagnose problem ‍
ajlsl600
france
I have had plenty of that. Where you keep the car
SL350BALLY
SL350 (R230)
  • #18
Outside, looks like there are additional fixed fuses underneath the passenger footwell, any info on the function of these and if they could have blown?
ajlsl600
france
You should have a folded sheet in Yr main fuse box giving that information. On my ml the lists in fuse box inder rear seat squab
ajlsl600
france
Reason I ask is rodents just love mb wiring
