ESP question
nick-E55
Bedfordshire
A dumb question from somone who is not the least technically minded....
If i'm a bit "over-enthusiastic" and especially when the roads a bit damp, the ESP light goes crazy, and i can feel it cutting-in. THat's a good thing as it stops me from ploughing into the nearest hedge :eek:
However, when the roads are really bad, you're advised to turn it off. This morning was a good example: part of my driveway has a steep slope, and after negotiating that at 6am this morning, i then slithered up the lane which is both steep and ungritted. In order to get MORE traction, i had to turn the ESP off.
I tried at first leaving it on, but it was a nightmare, and just psna the wheels on the driveway and couldnt get up the slope. When i turned it off, the traction improved considerably.
So, i was wondering why that was??
cheers
Nick
daveenty
The Frozen North :(
2019 AMG S Class Coupe
Basically (and I'm not over technical either) the ESP recognises wheel spin and tries to compensate for it by shutting the power down to the offending wheel(s)
By turning it off, you're using the wheel spin to help you get grip on the mushy stuff and keeping both wheels moving. (Has the E55 got LSD? Got one and don't know myself)
I'm sure that someone will offer a far better explanation than this, but this is only my opinion.
ESP is only concerned with directional stability and would be confussed in this situation,and by turning it off it allows the traction control to work as it should.
Malcolm
nick-E55
nick-E55
Bedfordshire
ah, so ESP different from traction control. THat makes a bit more sense then. THe E55 doesnt has a LSD.
cheers
daveenty
The Frozen North :(
Sounds logical to me as well Nick,
We live and learn :)
I just drive it (and wash it occasionally)
nick-E55
nick-E55
Bedfordshire
being able to wash the car is about as far as my technical expertise go :cool:
ricky s
sussex
as signature
excellent nick i,ll bring mine round for some of that expertise, love my car, loathe washing it
nick-E55
nick-E55
Bedfordshire
I'll be round first thing in the morning Rick with my bucket and spoung :D
Howd u get on this morning?! ....rear wheel drive, auto, fat tyres.. and 500bhp... not exactly cut out for artic conditions !
type49
First there was ABS - we all know what that is. After ETS & ADS which were a bit crude but not bad, came ASR. This is a traction control which is like a "mod" on the ABS system. You cannot have ASR without ABS. ASR will apply rear brakes + reduce throttle to TRY & stop wheelspin. You cannot switch off ASR completely. The ASR button will only stop the reduction of throttle overide, the rear brakes will still be applied if needed. ESP is a stability programme. ESP requires ABS + ASR & uses both of these features as well as ESP. ESP will apply brakes to correct understeer/oversteer situations. The main system parts (compared to ABS/ASR) are a steering angle sensor (to measure the angle of the bend, or, where you want to go) & yaw sensors, which measure actual direction (are you going where you want or are you going straight on when you have the wheels turned(understeer)). With these sensors it will keep you on the road as best as poss by braking a rear wheel on one side if you are understeering & braking a front wheel for oversteer. They also measure up/down movement. This can be effective if you are speeding over the brow of a hill & slam you brakes on. There will be a chance of the rear braking away even in a straight line. With ESP, the rear brakes MAY be activated a fraction before the fronts to pull the rear of the car down to aid stability. There is a lot more to it than this but I hope this makes you understand a bit more rest assured that MB stability programme is the best system in a car at the moment. Switching off the ESP button again switches off throttle intervention but the brakes may well be applied by the control unit if it feels necessary. So doing burnouts in your SL55 etc will burn your rear brakes out!
Dave's E55 AMG
Newton-Le-Willows
So what you saying?
type49
With an E55, I'm sure you've put it to some degree of testing even if you didnt know it. You just need to be thankfull you've got it , even if you only ever really need it once.
Hibbo
East Scotchland
There was a thing in the paper a year or two ago where they got a group of people to drive a new car around a course with all the electronic helpers, then put them in a late 80s bm 325 - the result? Cones everywhere!
Do we become too reliant on these gismos? Especially ones we don't even realise!
type49
You cant beat an early BMW for sticking to the road like a wet bar of soap.
BarryG
Sunderland
:rolleyes: So Esp isnt the car reading your thoughts and preempting your actions?:rolleyes:
Barry:lol:
Barry:lol:
ESP= Extra Special Power
Plenty of rude versions.:cool:
malcolm
nick-E55
nick-E55
Bedfordshire
  • #20
I had no idea it did all that. With just the press of a little button. Also nice to know you're actually getting something for your money, as opposed to a gimmick. One thing i do know is that it's cut-in many times on wet roads, and having done track days in the past, i'm not stupid enough to ever turn it off... except once, just to see what happened... and a lot of sideways action is what happened :eek:
Thanks for the comprehensive reply.
