Factory alarm / immobiliser?
matei72
Bucks
2000 E200 Kompressor, LHD and 2015 C300h W205
Hi all,
According to the documentation, my wife's 2000 E200K Classic should have a factory alarm/immobiliser, but I don't see any evidence of such a feature.
The previous owner fitted a mr. happy shopper alarm to the car (Mundial K9), which has it's own key fob. It doesn't appear to be anything but an alarm.
The factory remote central locking works fine - but I don't seem to see anything on the keyfob that would lead me to believe that it has the factory alarm installed... is there anything in particular that I should be looking for?
M
matei72
Bucks
Good call... lots of interesting info, but nothing about an alarm though. Thanks for the link!
This must be why the previous owner fitted an alarm:
189 emerald (green) black metallic (с 1993)
Options
260 elimination of model designation on rear lid (с 01.05.1968)
414 electric tilting/sliding roof in glass version (с 01.10.1988)
423 5 speed automatic transmission / nag (с 01.03.1994)
801 Change of year of model, last figure shows new model year
926 emission control eu4-measure 30.11.1991 (с 09.09.1997)
988 ownership certificate and COC papers with EC model plate (с 01.06.1993)
050A Unknown code
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Your factory fit immobiliser is incorporated in the key, another way to check for an alarm would be if you have movement sensors on the top of the "B" pillers, also there could be a switch on the dash to switch the movement and anti-jack up sensors off.
M
matei72
Bucks
I've only got the central locking button on the dash... I'll go and mash the buttons around on my keyfob and see what happens.
bigasotonuk
Southampton UK
The immobiliser is automatically enabled/disabled by the key being placed in the ignition switch, and nothing to do with the fob buttons.
Alex Crow
Super Suffolk
your car, and all modern cars, will not start without the correct key. your key contains a transponder which emits a bit stream code when excited by the ignition switch. try putting in someone elses key and you will not hear the stearing lock withdrawing, nor will you be able to turn the key. if you forced the key to turn the engine would not be started as the ecu needs to recieve the drive authorisation signal from the ezs/eis module. there is no simple way to bypass this process without changing both the eis and me-sfi modules and, perhaps, the egs module also.
basically your car can only be stolen with the key, or a recovery truck with hiab type hoist.
M
matei72
Bucks
Ah, thanks guys - I understand now.
type49
I think the fact that your car is left hand drive, it possibly doesn't have a factory alarm.
M
matei72
Bucks
Good point. The alarm fitted is... OK. It makes an awful racket and is very sensitive.
