fault code help please
G
Gillsfan
I'm looking for some help with some fault codes please. I've just changed thd head gasket on my 2000 x reg vito 2.2 cdi. I'm currently in limp mode and a mate with a snap on code readr had read the following codes
P1482
P1481
P1622
The first 2 acording to the code reader are glow plug codes, I fitted new glow plugs when I changed the head gasket. They both clear then come back the P1622 won't clear and is according the reader is a switch out v/v.
Thank you in advance for any help I receive.
G
Gillsfan
Thank you this is what I found any suggestions welcome
P1481 Glow plug failure Cylinder 1
P1481 Glow plug failure Cylinder 2
P1481 Glow plug failure Cylinder 3
P1481 Glow plug failure Cylinder 4
P1481 Glow plug failure Cylinder 5
P1481 Glow plug failure Cylinder 6
P1481 Glow plug failure Cylinder 7
P1481 Glow plug failure Cylinder 8
P1481 Glow Plugs
P1481 pre-heating plug fault
P1482 Glow output stage N14/2
P1482 N14/2 (Glow output stage) Cable fault (Short circuit to ground)
P1482 N14/2 (Glow output stage) Communication fault
P1482 N14/2 (Glow output stage) Excess current
P1482 N14/2 (Glow output stage) FAULTY
P1482 N14/2 (Glow output stage) Implausible reception byte
P1482 N14/2 (Glow output stage) Incorrect diagnosis sequence
P1482 pre-heating plug output stage N14/2
P1622 Injection pump shut-off valve
P1622 turnoff valve Y75P1622 Y75 (Electric switchover valve) Open circuit
P1622 Y75 (Electric switchover valve) Plausibility
P1622 Y75 (Electric switchover valve) Short circuit
P1622 Y75 Electric switchover valve open circuit
G
Gillsfan
In an effort it assist any fault diagnosis here is what we did last night. Plugged in the code read and checked codes it came up with 5 in total, cleared the codes (the 1622 wouldn't clear) started the engine and checked the codes again it came up with the 3 I listed above. Cleared the codes again still the 1622 won't clear, i drove it around the block and checked codes again, still the 3 listed above. We then stopped looking at the van and drank some cider awaiting google info/advice from you good people.
G
Gillsfan
I found the fuel cut off valve connection was loose. It's now on and I've cleared the edc light and the limp mode.
VinoVito'd
CONSETT
Vito 638 2.2 CDi
Hi Gillsfan.
Same problems here it seems. Though from what i can gather Y75 is specific to the Vacuum Valve under driver wing?????
did you find any other definitive proof of the problem?
Cheers. My head is done in!
VinoVito'd
CONSETT
Vito 638 2.2 CDi
I should also add though that my fuel cut off valve is not connected (fuel wise anyway) It's been off a while and rusted in the closed position. I have access to OBDII and cleared it several times with no improvement.
mutleyomels
Essex
C270 Year 2005
Fault Code No P1664
Car is a 2005 C270 showing fault code P1664.Problem is with Kick down,so much black smoke the road cannot be seen,on normal pull away it also smokes,then it will clear. Any help i would be most grateful.
Craiglxviii
Cambs UK
P1664 Electric heater booster equipment fault
P1664 electric heater fault
P1664 electric heater open
P1664 electric heater output stage fault
P1664 electric heater short
P1664 heater
P1664 load signal of electric heater motor implausible
