Help needed please,
My 2013 E220cdi keeps showing this fault code.
It is having much problem starting first time in the day, if it is cold outside then it might have starting problems all thru that day.
Upon sitting in the car to start i watch for the heater lights to go off, then i turn the key.
NOTHING HAPPENS, the lights in dash do not dim at all.
I can turn the key many times, most times when it does start it is as the key is on the return ( disengaging from the full start position)
The above fault code is the same from MB dealer ship as with the AA
Sometimes i get the attached message showing on my dash
Thanks from Michael
Thanks from Michael
