Fault code reader
ADP
Worcestershire
C200K, SL500.
Does anyone know if it's worth buying a fault code reader/clearer. Do they work? I've seen many advertised but are any of them worthwhile.
ADP
Its fairly easy to get a reader for engine faults, but for other things on MB cars a dedicated reader is needed, and these are expensive
Miffy
Bromley, London
CLK 320 CAB Elegance C208
for the £60 they cost you might as well, as most garages wont have anything better, unless they are merc specialists.
A
ADP
Worcestershire
C200K, SL500.
So they are no good for electronic faults? Just wondered if they were worth buying as many state they can be used on all car makes. I have two merc's and two VW's and repair the majority of things on them apart from anything to do with the OBD.
ADP
Miffy
Bromley, London
tells you what faults (engine orientated) you last had, fuel mixtures, and stuff like that, and most allow you to clear the fault
if your local to me, or we go to the same meet, your welcome to play with the reader I have to see if its worth you getting one
A
ADP
Worcestershire
C200K, SL500.
I recently had my C200's wiper sensor reset and it cost £49. So that kind of reset would not be possible then?
ADP
Miffy
Bromley, London
No, i think thats fixed with a STAR system, way more advanced than the code scanners
No it would not cover that, just engine and running gear
A
ADP
Worcestershire
C200K, SL500.
Thanks for your advice. It may still be worth buying one for the engine diagnostic. Anyone have any recommendations as to which brand and type to buy? One that covers most cars would be good.
ADP
Miffy
Bromley, London
AS far as I know, the engine fault codes all follow a standard (ODB II), so all compliant readers should at the very least read all of the data, and I guess reset the error code.
Some info on the OBD II standards and buying guides can be found here
http://www.obdii.com/scantool_selection.html
nickcc101
Helston Cornwall
Just bought U581 from Amazon app £70. Scans, lists codes and resets. Also performs checks when engine running. As stated by Malcolm and other members, only covers engine and Star still needed to clear other faults. Still saved me two visits to Inde At £40 each. Can be bought off ebay for app £60 but prefer fully guaranteed warranty. Can be updated via website, all cables provided.
prc6
Guildford
1997 CLK 230 Kompressor that needs a bit of work
In the process of thinking of buying one of these ELM327 USB to get the codes from my CLK as going to my local dealer for £40 a time seems like a waste to get the engine codes. Just wonder if anyone has had any experiance with this one at all. Also am i right in thinking i would need the adaptop cable or does the Mercedes also have the 16 pin connector?
I have been looking at the hand held units but would prefer something that i can run on my laptop. So if people have other recomendations i would be happy to take a look.
I have though about possible buying a star but woried i might do more damage with it and also it is a lot of money.
Pete
I would check Pete with the makes you do not have the 16 connection,only the 38 pin
