Fault Codes (P1615 and P1630)??
oz2022
Just had my E300td plugged in and these are the error codes:
P0100 Mass Air flow Sensor
p1481 Glow plugs
P1615 Control Module Supply Voltage
P1630 Drive Authorization Signal
Im unsure about two of these error codes. Does anyone know what the P1615 and P1630 error codes mean, or what these two codes are linked to, im guessing the (P1615 Control Module Supply Voltage) could be to do with the battery.:confused:
any help appreciated
Just to help, what was the fault
O
oz2022
after reading a post from the DIY section (W210 Stuck in gear) i think i have the same problem with car sticking in gear forcing me to drive in D4.
it does say that problem is related to the voltage or the battery, so im thinking this is the reason for the P1615 error code.:confused:
A meter to test with only cost £5 and the test is best done before the car is driven where it should be 12v or over, if the meter is left joined up when starting, then one can see the voltage drop that takes place, when it drops too far then starting blips are recorded and the components cannot reset
