Fault Codes.......
Trueblue1872
Scotland, United Kingdom
W203/2004/1.8 Kompressor
Hello again folks,
after getting an intermittent engine management light on my w203 c180 Kompressor i decided to dive in at the deep end and purchase an OBD2 Scanner tool. i have been since still getting the intermittent light after clearing the codes. they are as follows:-
P0101- Mass/Volume air flow A circuit range performance
P0102- Mass/Volume air flow A circuit low
P0172- System too Rich Bank 1
P0171- System too Lean Bank 1
my question is this, all of my ideas point to a fault MAF sensor, but i was wondering could the problem be caused by an oil leak?
any info would be greatly appreciated.
thanks guys!!
Uncle Benz
West Sussex
Mainly Mercedes
On an M271 I would be checking thoroughly for split or perished breather hoses first.
Trueblue1872
Trueblue1872
Ok so all the hoses should be checked and thats maybe causing an air leak
Uncle Benz
West Sussex
Mainly Mercedes
Yup. The air mass will register as low if a leak exists downstream of the maf. Consequently the fuelling will all be to cock. Could still be a faulty maf, but eliminate the cheaper stuff first ;)
Uncle Benz
West Sussex
Mainly Mercedes
You mention an oil leak... If you have a hole big enough it can also be letting air in via the breathers and messing it up the same
Trueblue1872
Trueblue1872
Ok well my fuel MPG is ridiculous and my shifting through the gears isnt very smooth at all.
Trueblue1872
Trueblue1872
Where the MAF is situated in the w203 c180 is a bit kf a pain to get to also
Trueblue1872
Trueblue1872
also with regards to the oil leak my suspicion is that it may be coming from the camshaft magnets located at the front of the engine
Oldspanners
Normandy
C CLASS 2004 C180
That could be the source of your problems if the oil is wicking into the wiring harness. Check the connector at the ECU and at the post CAT O2 sensor (the lowest point) for any oil contamination.
I chased a fault on mine for a few months with this.
Trueblue1872
Trueblue1872
Ye i think this is the problem becausr the area in and around the camshaft magnets is thick with oil.
