kito
- Jun 26, 2012
- Location
- Aberdeenshire
- 2010 E Class 250 CDI
kito
Hi I Am also new to this Forums
I Am not sure about the SLK but most cars now has a electric fuel pump normally at the rear there's a good chance you will hear it running try just turning on the key to the on but don't try to start it just for a min or so if you can hear pump it may stop once it has built up pressure in the lines then after the min turn the key off then on again and try starting????
Also try filling the fuel tank to the neck the night before if the fuel is running back with a full tank the pump will be lower so should stop it???
