Filter change only
malagabob
S wales
a200 amg 2014
2014 A200 W176. Looking at the position of the oil filter, it seem high on the engine. Is it possible to change oil filter without dropping oil out of the engine.
Naraic
2005 CL500.
I hope so...or else your engine is full of oil...bad.
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Yes, and if you pump out the old oil, as discussed on here loads of times (search for oil change), you can do both whilst stood up drinking tea.:):)
umblecumbuz
Wales and Gozo
That's no good for Malagabob.
He doesn't drink tea.
daibevan
Alltwen, Pontardawe
Sangria or San Miguel wold do just as well.
DREAMER NO2
W124 2.6E M103 1989
If its a screew on ,,or spin on filter , then they do have a no return valve inside .So it will be a clean job removing them . To remove the one thats lift out then if you remove the top ,then with a hook pull up the wire on the side and lift it out . But use a container to put the old filter in .
Submariner1
Windsor Berkshire
CL500 2009 5.5
Puzzled why for the sake of what 4.5L of oil ... you wouldnt change the oil.
The chance of all that goodness wasted. ;)
