Janchee
Hi Jimbo ... we will get to the end result soon!!
I’d say to make sure you take some run out measurements and at least 8 disc thickness measurements when you next have the wheels off. This will give you a good numerical backup for investigation going forward.
Usual Sunday job of checking car - found that all my cooling holes are blocked up as well. For mine - I’m still convinced the problem appeared after using active cruise control. It uses the brakes so much more than I would. Loads of forums online describing the same problem. Discs aren’t warped but loads of brake pad material baked into the disc. There’s also a bulletin raised for the SE version:
LI42.10-P-066910 AUG17 213 without AMG juddering/shuddering of the brakes at the front axle can be felt when braking, check the wheel assembly components disc brake & brake pad condition, wheel imbalance, suspension & steering parts, and wheel hub contact surface. If none of the components are visibly or measurably damaged replace brake pads.
Just checked my tyre pressures as well ... 48psi on the rear!! Who the ****** hell set them at that is beyond me. I was wondering why the car was coasting so easy Now at Manf setting of 32psi all around and it’s a lot better haha. Going to ask the last service centre for a copy of the tyre pressures if they checked them at all.
