First S63 Quibble
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
The car is amazing in everyway and everything that I wanted.
BUT.................(I might be picky here)............ imagine your driving along in C mode traffic comes to a stand still and you brake and the car stops, the traffic moves 5ft and you coast along. wishing that 2/3mph window the car has a slight judder but soon at you reach around 4mph or put your foot on the accelerator its as smooth as silk. I did notice this on the way home but sitting in the car for 6 hours and it being new I dismissed it. Yesterday and today it's the same, not horrible but noticeable. When its in S mode the car pulls off very smooth but louder obviously.
I have a mate in Newcastle that has one and asked I to see if its the same and he said its exactly the same. Weird design fault from a 100k plus car. if im correct this car has no torque convertor and a MCT wet clutch? just one of the things I guess has to be S mode round town :p:p:p
malcolm E53 AMG
Do the revs increase slightly when you select Sport mode if so it may just be the lower throttle setting causing the slight hesitation
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
I think it does to be fair. it's only when coasting along, The wife doesn't notice it but I do, other than that I can't find any other flaws :p
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
A quick read online and yes it's a wet type clutch affair , one author stating the points of contact of the clutches can be manually adjusted and gear changes can be adapted. Obviously a specialist field of expertise. Quite a few complaints about snatching from 3rd to 2nd also.
https://www.reddit.com/r/AMG/comments/as2sk9
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
very interesting, sounds about right the snatching gears I haven't noticed as yet. one thing iv noticed is it a B*****d to park in any kind supermarket or car park. the 360 camera makes it slightly easier but do you trust it :D.
if I notice it getting worse ill be taking it in for a check over, just seems strange how the s class is meant to be all comfort and luxury but actually feels like a
a auto box is about to stall. (bit dramatic)
SL63 Mark
The South
R231 SL63 AMG
No it definitely should not judder in C or any other setting, it may mean the transmission mounts are on their way out, or the prop shaft vibration damper. I have no idea the above is total guesswork, but there was a prop shaft vibration damper on my SL55 which was starting to break up, so I got a clunk sometimes.
Hopefully an easy fix, worth taking it to a reputable independent near you for a quick look over on a ramp.
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
I thought the same thing, but why does setting C to S make any difference surely the clutch would engage in the same way? I read about the auto brake function having an effecto_O
onefortheroad
uk.
Do you know if the gear changes are sononid controlled? Maybe time for an oil change ??
C to s will possibly differ in the speed at which the gears engage and disengage , controlled by the ECUs. Try sports + it's mental
malcolm E53 AMG
Sport setting generally uses a lower gear ie 1st and Comfort 2nd gear so the slightly higher gear ratio may cause the drivetrain to judder (semi stall) at lower speeds it may just be that the gear ratio is slightly high - does Daveenty’s car have the same characteristics if not it would be a good idea to compare the two gearbox specifications
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
Full service done 250 miles pre collection from MB inc trans service. I went the MB carlisle today to get a print out to be sure and it all seems to fit out. although there is a few little gaps. but the milage seems ok. IMG_2826.JPG
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
thats almost what it feels like setting of in a manual in 2nd gear.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
No 2022 or 2023 service?
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
this is just what id found out today. the guy at MB said its not an issue as the mileage is low between them. but would have been nice to have yearly services. looks like its ben sat for a while
malcolm E53 AMG
It’s certainly been cared for terrific service history synthetic oil doesn’t degrade as quickly as mineral oil so nothing to worry about at all re the slightly extended intervals
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
thanks for that Alex and Malcolm, sort of puts my mind at rest. seemed to be too much of a coincidence as a few other owners have the same issue.. while your here @alexanderfoti Any other issues to look out for? seems to be running ok? your expert opinion always helpful.
All very reliable. Just the usual m157 things, so crank breather leaks etc. your lucky as pre facelift car has ABC, far superior to airmatic on the later ones.
Keep on top of servicing etc and it will be reliable. We look after one chaps and he does 30k a year. He has had it since new, now on 150k no issues apart from maintenance
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
  • #18
Thanks Alex :D
