fitting a bigger output turbo ??
MICHAEL31
Nr LINCOLN
e270 cdi classic auto
y get slaughtered for this but I am going to ask, has anyone fitted a larger output turbo to a e270 cdi w211 2003. is this possible, is it strictly non advisable ?? any info appreciated. thanks
Craiglxviii
Cambs UK
Without remapping the engine it won’t do much... and then you could go a long way by remapping the engine without changing the turbo...
rf065
Grossbritannien
A larger turbo will take longer to spool up, you will have more power at the top end but next to nothing at lower revs.
Russ
om613
london
S202 C250TD, S123 240TD
No.
The only physically bigger bolt on you can "possibly fit" that will improve performance is the charge cooler / inter-cooler.
V6Matty
Newark, Nottinghamshire
A blended map will see the 647 push 225bhp, go for a full power map and you can see very close to 240 with no parts changed
Be careful to check which gearbox you have to ensure you don't overstress it.
Craiglxviii
Cambs UK
You mean, just wing it and see what happens? ;)
If thec270 uses a WA580 then not likely to be a problem but if it's a WA330.......
V6Matty
My old 270 from 03 was the 580 Alistair, so I'd be pretty comfortable saying this one will be the same
Botus
S500/2010/500
Russ
it will go slower..... you will lose pick up off the line and the waste gate / electronics will limit the boost to same at the top end as u have now....
M
MICHAEL31
Nr LINCOLN
thanks for all info/advice guys. I think after reading it all I will leave that part standard. had a lot done already, be content with what you got im told lol, thanks
Westheath
South London
Use the 320CDI OM613, Garrett GT2359V.
Replace the MAP sensor
3bar A006 153 9928
4bar A007 153 0028
Ideally find a bigger inter cooler.
Then re-map.
The AMG 8 hole nozzles are a nice addition if you can find them these days.
iirc
There were some Finnish guys doing 270cdi modding
https://mbworld.org/forums/diesel-forum/236318-e320-cdi-mod.html
rf065
Grossbritannien
A bigger turbo will force more air in, even if it is at the same pressure. As long as you supply more fuel to the extra air you now have, power will increase.
Russ
Russ
Only if it adds more fuel.
Tel: 020 8863 9233
