fix for heated seats
basssman
west of ireland
w210 320cdi 2000
Hi there, does any one know if there is a common fault with the seat pads?
Drivers heated seat (base) has stopped working, must sense winter is here!
What are the things to check and are there any cheap replacements. I presume you have to remove the leather trim etc. Any help gratefully recieved..
Michael..
Dazzler
Haverhill, Suffolk
W211 E320 CDi Estate 05
I have been told that the wire breaks where the seat base meets the back of the seat, seems it fractures where the recline point is.
Does the back still heat up??
If not the above then a new pad will be required.
Yes you have to remove the cover to replace the mat, the mat is stiched into th eleather, so the new one you just lay under the leather cover.
The wires often break that go to the pad,,and these can be repaired.
I can give you all of the info to get the seats out and remove the trim
B
basssman
west of ireland
w210 320cdi 2000
Hi thanks for the replies, yes the back still heats up. Thanks Malcolm I would like the instructions for removing the seat covers etc.
Michael..
I have sent the 3 that you need, when you get to the heated pad just post and we can talk about fixing it
racall
london
c class and slk
I think my back rest has stopped working and i am sure it used to do. 2000 R170 Is the element in the cover or the foam,
Yes there are heaters in the back rest, would you like the details of doing the work
racall
london
c class and slk
Yes please malcolm
I looked under the seat for the plugs but cant see any,i,ll whip the seat out.
I need an email address please. You could just remove the rear cover but not much room in there to see or work
racall
london
c class and slk
Just wondered how i can recline the backrest when the seat is removed and disconnected as they are fully electric.
OK I will print of what you need and post back shortly,,then you can remove the address
4 Papers sent to cover all of the job,,,you could pause when you get to the connections on the seat heater,as these can be tested from there without going further in case the fault is a broken wire going to the back rest :D
racall
london
c class and slk
Malcolm
Have you AR91 10P 1070GA
Remove seat squab with electric seats.
The A prefix at the end denotes electric seat adjustment Code 560
I might,,and there again I may not
Being as it is you I will find it and send it :D
racall
london
c class and slk
Heated seat backrest
The backrest heater wires are broken it seems i think i need a new foam pad as i cant find the other end of the wire.
I wonder if ollie has ever stripped a seat down to replace a broken pad.
Has anyone got a part number R170 449
racall
london
c class and slk
Thanks malcom
I wonder if part #160 is the foam with the element in.A1709101816
Part #170 seems like the leather cover to me.
As there is only on wire shown in the link,,that could be a twin wire so you still have a good chance of fixing it
www.W140.co.uk&www.r129.co
