Flashing indicators
Vitonewbie
2006 Vito 2.1 RWD
Hello all
Just brought a 2006 Vito 2.1 when locking with key fob the indicators are flashing when the vehicle is locked?
Any ideas
Cheers
Hello and welcome
They should flash 3 times to show it is locked. If it goes on for longer then it indicates that one or more of t doors isn’t closed. It can also mean on some that the batteries in the key fob need replacing
V
Vitonewbie
2006 Vito 2.1 RWD
Hello and welcome
Blobcat thank-you for your reply I’ll check what you said and go from there.
How reliable are the Vitos I’m first time owner.
It’s a 2006 2.1 RWD done 150k. Just wanted some pointers really.
Cheers
We’ve a few owners on here @M80 and @Kev555 should be able to advise
A.J.
Norwich. UK
Hi and welcome to the forum :)
Kev555
N.I
Welcome Vitonewbie, Yes as blobcat has already mentioned the indictors should flash 3 time when the van is properly locked. if not its usually one the the side door multipin switches/strikers usually need a clean.
M80
Derbyshire
1st test is to press to lock a 2nd time, if that extinguishes the indicators it is then likely that the alarm sounder is goosed. That is assuming yours has the alarm as many don't.
Otherwise as Kev says check the doors are locked.
If one isn't locked go in lock it from inside, exit from another door and then try to lock with the fob. That might show which door is the issue.
