Here is the next one
It should be under the black plastic cap. REMEMBER IT IS LIVE! Check it with a multimeter and see if you get voltage, normally 12.8v but in your case more likely 10v-11v. Then connect a 12v source positive to Live and Negative to an Earth on the car. You should be able to unlock the car now.
To me it looks like the closer cable that wraps around the starter is the feed from the solenoid.
That would make the cable that goes behind to a hidden connection the feed from the battery, although in your case the 'back' feed to the battery.
As said there may well be a plastic cap on it.
If you power up the visible terminal the starter will spin, if there's enough capability in whatever your donor is., that's not a problem,
but it would be the other that is needed to back feed to the battery.
TBH honest I would like to see a photo of where the cable goes to that is clamped by the terminal we can see.
But my thinking from what I think I see is that the terminal you want to connect the +ve 12v to is the terminal at the end of the heavier cable that I think is coming down from higher up (not sure of the orientation of your photo).
From the battery / fuse box there is a feed to the starter solenoid.
This will come down from higher in the engine bay and is the +12 volt feed you need.
Here is a video. fast forward to 2'19. This is what you are looking for. The Live has a cap on it. Remove the cap. That is a permanent Live to the Solenoid.
The answer would appear to be that it wraps around the back of the starter, then to where I don’t know.Ok, thankyou, and apologies if I’m coming across as dim.
On the attached pic, there is a yellow arrow, pointing toward the front of the car.
The photo that you want to see of where the cable goes to, is that the cable on which I’ve put the green arrow, and is the arrow in the direction that you want to see?
